Originally Posted By: jimmy87
4 cylinder? Really? Who wants that? Might as well get a Camry, the 6 cylinder is a gas guzzler and you know it, that's why you brought up the 4 cylinder, 1300 pounds of top soil, like I said before your endangering the good people on the road, a properly equipped ranger (2011 model) has a max payload of around 1500 pounds, your not going to tell me that your older one or a 4 cylinder is even close to being rated to safely move 1300 pounds in the back of the bed, are you? Im sure the ranger is a reliable solid truck, not sure what the op wants to do with it as far as work goes, but despite me "bad mouthing" the ranger I would still recommend it over the tundra, but if it where me i would rather have a v6/v8 f150 for work.
Who wants a 4 cylinder? Umm, me. If Ford offered the 4 cylinder with 4wd, I would've gotten one. But, I had to get the big V6. Yes, it uses about as much fuel as a half ton. I STILL prefer the Ranger over a half ton. Gas mileage isn't everything. Half tons are way too big, bulky and impractical for my uses. I actually almost bought an F150 before I got my Ranger. I'm glad I got the Ranger instead. It does everything I need it to and more.
And yes, my truck can SAFELY haul that much in the bed (hint: my "older" truck as you call it is EXACTLY the same as a 2011 Ranger; Ford didn't make ANY changes whatsoever between 2006 and 2011). And as 01Rangerxl said, even the 4 cylinders can carry that much.
Why don't you just stop now before you make yourself look even more ignorant than you already have?
