Originally Posted By: chubbs1
Originally Posted By: skyship
Now this is the funny part because it's not a real lube for life:
SynLube™ Lube−4−Life® does not oxidize nor decompose like conventional Petroleum or Synthetic Motor Oils. It can be therefore used, without oil changes, for up to:
• 15 Years
• 150,000 Miles
• 3,000 Hours of Engine operation in Gasoline Engines
• 2,000 Hours of Engine operation in Diesel Engines
[/i
The real funny part is the, "FOR UP TO" in the second line!
I could use my new Castrol Edge TD for up to 150K miles, but I kind of think the oil filter might not be happy and the rattles that will start and all that smoke from worn rings might not be too popular with the neighbours or the Police.
The engineering theory is interesting because if the fuel dilution offsets the carbon build up it might not thicken up too much and they did not say don't change the oil filter. Once it gets too thick the engine won't start and you have to change the oil.
The high Moly and Zinc might just save a full seizure for a long time, probably beyond the point at which the sludge blocks the oil pump intake screen and the low oil pressure warning causes you to think again.
One real killer will be the build up of Silicon particles unless you live in the mountains and drive on clean roads. That Silicon is probably going to be the real wear factor that chews up the rings and bearings and turns the block into a rattler.
Anyone want to give it try?? Also I would like to see a VOA just out of interest.
LOL! So true. I could use any oil "for up to 150k" When my car blows at 30k how are they going to help me?
Stay away from anything that sounds too good to be true!!! Nice Website too BTW...lol
If your new engine goes bang your lawyer will point out that they are a company with debts and no assets that is not worth taking legal action against without you paying his fees up front.
You would have to be mad to use it in a new car and invalidate your own warranty, based on the chances of claiming on theirs. I was shocked to read the new car warranty part, as not even snake oil companies write that type rubbish.
A lot of the info on the web site is interesting but I think folks miss the fact it is just another oil, but is sold with one incredible and useless warranty.
