I just recently got an old, yet well running 97 Ford Escort Wagon. My father and I just yesterday finished running two new rear brake lines as the original ones were really looking corroded so we decided to change them, rather than having problems down the line. We filled up the reservoir with DOT3 when everything was back together and then began testing the line by pumping the pedal many times to pressurize it. After a few minutes of looking around we found no leaks. We then began going from back to front bleeding the whole system until there were no air bubbles coming out of the bleeder valves. Now i'm not sure if this is normal or not, but if you pump the pedal with the engine off it becomes harder with every pump until you can't anymore, but if you come back say an hour later the pedal is lifeless...no pressure until you pump it a few times again. I thought the pressure was supposed to remain trapped in the booster when the system is off. Also when driving, the pedal is super spongy and goes almost to the floor, and when you really give the pedal a good hard push to the floor the cars begins to slow down , but the wheels don't even lock up a bit. So what is causing this? a master cylinder issue or brake booster?
FYI: we went around as well and inspected,greased, and cleaned all the pins and sliders. The discs and pads are in good condition.
Thanks
Thanks
