SO, I've got an H4 in my car and the engine seized after 24 miles on a headgasket job with new oil and filter. Got a re-manufactured engine and sent my long block back to the guy I got the reman engine from. He tore the old engine apart and said the oiling system was clogged due to some sort of solvent that was in the engine. Said the whole short block is toast (ie, melted pistons, bearing races, etc). My question is, can a solvent (engine degreaser) cause a blockage in the oiling system? If so, how? If anything it seems like it would break down the viscosity and you'd end up toasting the engine because of too thin oil. Or does degreaser end up thickening the oil? I tried to search for this scenario online and on here but was coming up empty handed. I'm pretty sure I lack the right vocabulary to know what to search for though so that doesn't surprise me. Any help would be much appreciated!
