Originally Posted By: dan_erickson
. . . what oil would you suggest I try next? I have about 10 quarts [of] Motorcraft syn blend 5W20 on my shelf right now. I am thinking of sticking to Motorcraft or PYB from now on because I do not put all that many miles on my car to warrant expensive synthetic.
Correct me if I'm wrong, but I think Honda specified 0W-20 weight oil for the 2010 Accord. If so and you are concerned about potential engine warranty issues, you're stuck with 0W-20 weight oil and, so far, there aren't any conventional or semi-synthetic 0W-20 weight motor oils available in the U.S.
That said, the Motorcraft ("MC") 5W-20 weight oil you have sitting on a shelf was manufactured by ConocoPhillips, the same guys who now bottle Honda's housebrand 5W-20 and 0W-20 weight oils. A slew of UOAs have confirmed 5W-20 weight "Honda" motor oil and Motorcraft 5W-20 weight are virtually identical, and both are semi-synthetics. As a practical matter, IMHO your Honda will thrive on the stuff (or virtually any other name brand oil, for that matter).
FWIW, the UOA/shearing result you posted seems like an anomoly. However, if you're really concerned, run a couple of MC 5k OCIs and see what the results are after that. In any case, unless you have some other reason for concern, I wouldn't worry about Blackstone's analysis.
The 2011 Accord switch to 0W20, but I plan to run my current fill of Mobil 1 for 5000 miles and test to see how well it did then switch over to MC and use up what I have.
The 2010 was back spec'd to 0w-20. I'd give that a try, but looking at your UOA, I wouldn't be worried.
