OVERKILL
$100 Site Donor 2021
So, being somewhat new to BMW ownership (M5 last August), I've only had a chance to do a few things (CPS, oil changes...etc, basic stuff) on them so far.
So doing the plugs on the 328i on Monday, I didn't quite know what to expect going in. It's a longitudinally-mounted straight-6 in a small car, I thought it might be difficult. I thought, like on the Expedition, that there might be accessibility issues.
So, not trying to be corny, but what I didn't expect was what I am now going to refer to as "German Engineering©".
I'm sure everybody has worked on their vehicle and at some point you ask "what in the heck were these people THINKING???" when trying to do something. Be it fear of breaking a clip, having to bend something out of the way to gain access, scratching your arm, contorting your hand/arm/body....etc. Or just cursing as you sit on top of the engine trying to get the plugs out of a 6" deep plug well that has fuel rails, A/C and coolant hoses running over top of it (Ford, I'm talking about you!).
Have you ever wondered what it would be like to work on a car designed by "car people"? I think older (pre "we don't need a dipstock because they are silly!") BMW's may be those cars. And no, I'm not trying to paint some idealistic view of BMW, they have had their fair share of moments too, but I DO think that in general, they put a lot more thought into how things go together and come apart than any other make I've ever worked on, and I've pretty much worked on them all except Mercedes.
For example, doing the CPS on the M5:
1. Remove two metal (they are huge) clips that hold the air filter in the cabin air filter box.
2. Remove box assembly.
3. Rotate cabin air tube assembly up 45 degrees. Slide out.
4. Remove 10mm bolt (they are all 10mm) to disconnect the wire guide.
5. Remove 10mm bolt holding CPS in place.
6. Remove CPS
It is all in "layers".
So, doing the plugs on the 328:
1. Remove cabin air filter: 3x spring-loaded twist clips
2. Remove wire guide cover and power wire/washer feed from filter tray.
3. Remove cabin air filter tray (the entire tray assembly comes off as a unit with 4x torx screws). This gives you complete uninhibited access to the top of the engine.
4. Remove bolt covers from engine cover
5. Remove 2x 10mm bolts and 2x 10mm nuts
6. Remove oil filler cap
7. Remove engine cover assembly. Replace oil cap.
8. Lift metal clip, slide power feed plug from coil (no breakable plastic clips)
9. Remove 2x 10mm bolts from coil assembly. Lift out coil. Remove spark plug. Repeat x5.
It wasn't the least complex spark plug job I've ever done due to the "layers" of things that had to be removed, but it was the most bloody logical one I've ever done on a "modern" car. The covers prevented ANY dirt or dust from getting near the coils, everything under there was spotless. There was only 1-size of fastener for anything that needed to come off and the entire job only took about 20 minutes because everything just came apart like it was supposed to.
Now, I've gone through some of the TIS documents and this appears to be "par for the course" with BMW. There is a layered approach to any job on the vehicle and it is all very methodic and well thought out as to how each task is to be performed. It is almost a tad anally retentive to be honest.
So, am I nuts, or has anybody else worked on a BMW and noticed the same thing? I'm not complaining, I think it is great, it is just very foreign to me (pardon the pun).
6. Remove CPS
