UPS package tracking is so confusing!
by Klutch9
41 minutes 43 seconds ago
Dupont non-stick lube
by buck91
47 minutes 19 seconds ago
House electrical wiring question
by road_rascal
47 minutes 39 seconds ago
Air pressure question
by aquariuscsm
50 minutes 39 seconds ago
Fllow the DOT's
by WyrTwister
Today at 07:23 PM
Auto Rx?
by coopns
Today at 06:54 PM
Rotella for 6.0L Gasser
by Joefuskie
Today at 04:40 PM
Pennzoil Platinum Euro 5W-40
by 1JZ_E46
Today at 04:21 PM
TGMO 0W20 7700 miles UOA
by micmac
Today at 03:45 PM
"Low Coolant" light doesn't vanish.
by OpenClose
Today at 02:07 PM
Is running "Engine flush" before a change legit?
by OpenClose
Today at 01:59 PM
Who Owns A Beater?
by Red91
Today at 01:09 PM
Dmax7901, carver1, Handy7rick, sicilien, Crater_77
57738 Registered Users
92 registered (2004tdigls, 97f150, 06AllAmerican, 01rangerxl, 69GTX, 2015_PSD, 5 invisible), 1637 Guests and 98 Spiders online.
57738 Members
66 Forums
248227 Topics
#2491533 - 01/12/12 05:04 PM Subaru Legacy, Running rich, idle problems
SubaruGuru Offline
Loc: Auburn, WA USA
I have a 91 Subaru Legacy Sedan L 5-Speed EJ22 Engine 140k.. Full synthetic oil every 3k, always!
When I start my Legacy, It idles fine.. 1,300 rmp's. then drops down to 700 rpm's when it reaches operating temp. Which is normal. The check engine light blinks a few times when I first accelerate but never seems to blink after first acceleration. When I push in my clutch, coming to a stop, the engine idles at 300 rpm's and jumps right back up to 700 after a few seconds of engine shaking. Its never died on me the few hundred miles I've driven it like this.. When stopped, sometimes it will drop back to 300 but jump right back to 700. Sometimes.. for a few minutes, the engine runs perfect, doesn't drop rmp's while stopping or stopped.. but will sure enough start right up again.
I cleaned the mass air flow, and sprayed carb cleaner multiple times down the iac valve intake tube.. not much of a difference.
Also been getting bad gas mileage, and fuel smells very rich
The CEL codes I got were:
16- Faulty #3 Injector
35- Faulty Purge valve
42- Abnormal idle switch voltage
49- Incorrect Mass air flow sensor
-These are all weird since I just replaced, the purge valve with a new part over 300 miles ago..
-All my injectors are in the right resistance range 11-12k ohms
-The idle switch did test faulty, but my car has been runnin fine for thousands of miles since I first tested it faulty. It could be the problem, but I'm doubting it. Its slightly low on resistance.
-And the MAF is deff the correct hitachi MAF sensor for the manual transmission. Its not throwing a faulty MAF code
I once put an automatic MAF on, only for a minute.. and the purge valve is new and shows the correct resistance, it seems as if they are old codes still in the ecu... but I've unpluged the battery many times for nights at a time.
Here's a list of the parts I have replaced, trying to fix this prob.
Ignition Wires
Ignition coil
Spark plugs
Fuel pump/strainer (because last time it was failing, sorta did the same thing but way worse.
Fuel Filter
oil change
#2491560 - 01/12/12 05:32 PM Re: Subaru Legacy, Running rich, idle problems [Re: SubaruGuru]
Warstud Online   content
Loc: MIchigan
Try cleaning the throttle body and plate. If that doesn't work clean the IAC.
#2491582 - 01/12/12 06:03 PM Re: Subaru Legacy, Running rich, idle problems [Re: SubaruGuru]
bk111 Offline
Loc: WA
What about your IACV? Bad VSS also causes some weird issues with these cars
#2491591 - 01/12/12 06:11 PM Re: Subaru Legacy, Running rich, idle problems [Re: SubaruGuru]
NHGUY Offline
Loc: USA
TPS? Vehicle Speed Sensor?
#2491756 - 01/12/12 08:12 PM Re: Subaru Legacy, Running rich, idle problems [Re: SubaruGuru]
The_Eric Online   content
Loc: Iowa
Some codes will persist. A while back, I was swapping engines in the wife's 1995 Grand Am, so naturally I had the battery unhooked. After getting it running I was still able to retrieve all the ABS codes stored from a persistent problem.
11-12k ohms? As in 1000's??? That seems high to me. All the injectors I've ever checked have read in the high 7 to low 13 ohm range. Get a mechanic's stethoscope and listen to each of the injectors as the problem is happening. This may take a few attempts. Mentally log the sound of each, listening for "the odd man out" which by the sounds of it, is number 3. Good, properly functioning injectors will sound crisp and metallic through the mech stethoscope. Bad ones will usually either have no sound or a muted, muffled sound.
Also, if you have a scan tool that will give you live data, please post it up as this will aid in the diagnosis.
Edited by The_Eric (01/12/12 08:14 PM)
Edit Reason: added content
2001 Hyundai Elantra 2.0
1998 Chevy Malibu 2.4
1995 Pontiac Grand Am 3.1
1979 Ford F-150 351M
#2491758 - 01/12/12 08:16 PM Re: Subaru Legacy, Running rich, idle problems [Re: SubaruGuru]
Audios Offline
Loc: Lyndhurst NJ
Mass air meter codes can also be triggered by a vacuum leak somewhere in the manifold or intake system. Listen for loud whistling or sucking noises. The car is leaning out due to the extra air getting in past the MAF and trying to correct.
1997 Audi A4 1.8t-LM 5/40 Synthoil Premium
2002 VW Golf TDi-Mobil 1 5/40 ESP
#2491766 - 01/12/12 08:26 PM Re: Subaru Legacy, Running rich, idle problems [Re: Audios]
Loc: Iowa
A MAF code can also be triggered by an engine running near stall speed.
This is one reason why I suggested the o/p posting up some freeze frame data... Otherwise we could be chasing our tails.
#2492306 - 01/13/12 12:53 PM Re: Subaru Legacy, Running rich, idle problems [Re: SubaruGuru]
Vikas Offline
Loc: NorthEast
Blinking CEL is never good; it indicates severe misfire. Usually it would be because of ignition system problems.
91 Legacy is too old for OBD-II and freeze frame data :-(
Edited by Vikas (01/13/12 12:53 PM)
