I installed a Gates belt on a Yaris two months ago. Since then, the owner has put on a few thousand miles. The belt drive on the system is manually tensionered.
Recently, the belt has developed an awful squeal. I presume this is because the belt stretched. When I installed the belt, I noticed it was a hair longer than the OE Toyota belt but was OK. At the time, I was able to tightened it to a reasonable tightness-- but it was as tight as it'd go.
Should I try tightening the belt more, or should I just replace the belt? Is it normal for aftermarket belts to require constant readjustment? I've never had this issue before with OE belts-- as in I've never needed to retension them after some use.
Thanks.
Thanks.
