Originally Posted By: Finklejag
This engine is direct injection. So will have to fight intake valve deposits throughout the life of this engine. You should look for a low volatility oil.
+1. This will be the most common future problem with this type of engine.
It seems a low volatility oil (low NOACK %) is the solution (for now).
Look at the datasheets and look at this data specifically.
If you can, choose a 0W20 over a 5W20, it will be better for your engine, and should also improve your fuel mileage.
