I have to drill a hole in hardened carbon steel. The piece of steel is 4.5 mm thick. There's already a 3 mm hole in this piece. The hole has to be widened to 3.8 mm.
Then I have to drill three more holes with a hair under 1.5 mm diameter. There are no pilot holes.
The piece of steel I have to drill is round and has a diameter of 11.35 mm.
What kind of drill bit do I need, and where can I get it?
