Have you ever seen a Channel Locks 2 or 3 mm thick? He obviously has a special needs situation. I have ground down cheap wrenches for that need but not down to that thin dimension.If there is a part that requires it, don't you think they already have a tool for it? Or use a Channel Locks or a strap wrench.
Not anymore. The part that requires this size wrench has not been made in 60 years. The largest size available these days is 32 mm. The people who have the larger size versions hold on to them because there are no replacements available.If there is a part that requires it, don't you think they already have a tool for it? Or use a Channel Locks or a strap wrench.
What's it for?
If I want it made I'll just give the specs to a machinist at work. I'd rather make the tool myself, though.Find a fabricator, give dimensions, get part. I bought this and have been happy with it:
Cummins SS Fan Clutch Removal Tool | eBay
Fits all Dodge Ram Cummins from 1989-2012. Compressed Ignition Cummins fan clutch removal tool. Includes one wrench for the fan clutch nut and one for the fan clutch pulley bolt heads. No need to unscrew the bolts for the fan clutch pulley, just place the wrench over the bolt heads.www.ebay.com
Cut with cnc laser. Maybe this outfit could make your one-off tool custom. You can see the rough cost to make based upon the linked item.
Probably not that hard to do with a drill press and a set of files. Mark the stock, drill small holes, cut carefully with the appropriate blade, file to an accurate fit. Then cut the tool out from the sheet stock once satisfied.If I want it made I'll just give the specs to a machinist at work. I'd rather make the tool myself, though.
That's my plan. Drill holes in the corners. Use a jeweler's saw followed by small files. Just wondering if there was a better plan. I'd hate to spend more than an hour on this.Probably not that hard to do with a drill press and a set of files. Mark the stock, drill small holes, cut carefully with the appropriate blade, file to an accurate fit. Then cut the tool out from the sheet stock once satisfied.
For a watch back go to Esslinger.It's for an unusual watch back. I can use a case opener with the kind of Jaxa bits shown in the picture but it's a little risky. A ring wrench is much less likely to slip and scratch the case back. And no, the sticky rubber ball does not always work. 12 and 15-sided ring spanners are available in a variety of sizes, ten-sided ones not so much.
10-sided is not available in larger than 32 mm. Esslinger and Otto Frei are where I buy my watch tools, parts,, and supplies. 10-sided is rare to begin with (Panerai and some Chinese brands, I think).For a watch back go to Esslinger.
10 Sided Watch Case Back Opener Wrench Spoonz Set of 8
This is a set of eight metal 10-sided case opening wrenches. They grip the watch case back easily allowing you to twist the watch case back off quickly. They will open those older model watches with ten sides up to 32.0mm.www.esslinger.com
