I know this has been discussed many times, but I had my first experience with the Toyota cartridge style filter yesterday. First off, it was a pita to get off. Had to finally break down and buy the Toyota spec'd filter wrench that would grab properly.
However, once off, what a great system! Bypass valve is built into the cap that you screw off. And for those of you that use Toyota's new filter design as reason for not needing a solid center tube... well you insert that filter into the cap which has a solid metal center tube that you push the new filter over top.
Excellent design which IMO removes the potential for poor quality valves, seals, media, etc. You can inspect the media thoroughly before installing the filter! A BITOGER's dream!
Just thought I'd share that with you all
