Hello all. I've been lurking around here reading and learning as much as I can about all things oil related. Ran into something and figured I'd get your opinions.
A friend bought a used 2004 Dodge Durango Hemi (without MDS) with ~65,000 miles on it and no clue as to the condition of the engine. This truck is used to deliver the paper at night - ton of stop/go.
I changed the oil at 70k with Mobil 1 5w-20 EP & K&N filter (great deal on both). I changed the oil again at 75,500 miles and to my surprised this engine consumed almost 3 quarts of oil in 5,500 miles.
This last oil change I used PP 5w-20 (4.29 qt) and PureOne filter ($3). I plan on keeping a close eye on the oil level this time around now that I noticed the problem.
I am thinking of stepping up to PP 5w-30 or perhaps a high mileage 5w-30. If that doesn't help might move to a 10w-40 HM oil. This Hemi does not have MDS so I can go higher than a 20 weight oil in this guy. I have also seen others mixing in MMO into the oil for its cleaning properties. Thoughts?
I have not witnessed any blue smoke from the exhaust and there are no other obvious signs of a problem other than the consumption. The truck actually runs real good and has a lot of power. It's not leaking out externally either.
How would you deal with this oil consumption issue? How would you clean up an engine that probably has had a history of cheap oil and very long oil change intervals?
