For those of you who remember this problem, it is still going on-- I have a somewhat mysterious coolant leak on my Saturn. However, lately the leak has become large enough that it goes through a pint of coolant every other week.
I had a shop pressure test the system cold (overnight) and perform a block test, neither of which returned any signs of leakage. As some of you had suggested, the leak may not be found and other measures may need to be taken. I have not had a chance to look into it further.
However, I did a long trip at high rpm (3k+) and at the conclusion of the trip, there were traces of coolant on the engine block near the oil dipstick area. So, I think the leak is most severe when the engine is hot and being operated at higher rpm.
To narrow down the location, I pressure washed the engine compartment clean (shiny clean) and within 3 days (and only 40-50 miles of driving), I saw these spots:
Clearly, in the second picture, that red dot is Dexcool and the brown/reddish deposit is coolant, right? That area was shiny metal just 40 miles and 3 days ago.
As a side note, the radiator, water pump, heater core, radiator cap, upper/lower/bypass hoses and thermostat have all been replaced within the last 20,000 miles.
So, where could that coolant be coming from? An external headgasket leak?
Thanks.
Thanks.
