The thing is it is kind of a less than optimal solution. Putting a secondary injector in the intake has to take out some of the gains that di brings. Just saying there has to be a better way to fix the problem.
Though I'm partial to the idea that the DI engines with higher fuel dilution are the ones getting higher deposits. In other words the high fuel dilution creates more gases and fluids that the pcv must suck up. So getting dilution under control could very well bring the deposit problems down.
