Originally Posted By: Tornado Red
I don't see the connection. If EGRs are going to clog, they could do it in a non-DI engine.
I work on Mitsubishi GDI engines,and common rail direct injection diesels - the amount of deposits has to be seen to be believed,in the GDI it almost blocks the intake ports.The deposits are after the EGR port,some is from the PCV,but the large amount of deposits are EGR.
We had a Nissan ZD30 apart last month,this is a direct injection,but not common rail diesel.It is 4 valve,with completely different ports and runners for each valve...one valve does clean air with PCV,the other is the EGR intake.Only the EGR ports and valves had heavy deposits,the other intake system had oily ports with no deposits.
In theory EGR may not cause problems,in practice it is a very big problem.
