Originally Posted By: crw
I had a FRAM on my 1.8T, and it caused a startup noise until I changed it. For what it's worth...
The 2.5 is a very different engine and different filter design. It uses a cartridge filter. There is no ADBV on the filter. If there is something like an ADBV there, then it's part of the housing, not the replaceable filter element.
Quote:
I would not care where something is made, but rather how it's made, to what specs it's made, etc.
The point here is that if it's a FRAM made in Germany, then it means it's not really made by FRAM but most likely by some OEM filter manufacturer that actually knows what they're doing.
FRAM outsources the manufacture of filters which they have no capability of making. And that's a good thing in this case.
Also, why is this posted in the diesel section?
wrong forum. Sorry, need to read more carefully. The Fram filter is $8 vs $12 for the OEM online. I was just thinking for convenience sake I could use the Fram if its acceptable.
OCI is 10,000mi. The car is a 2009 Volkswagen Jetta with a 2.5L gasoline.
