Originally Posted By: chad8
wix numbers- any filter with a 20x1.5mm thread and 2.475 od will fit. Don't split hairs . either filter is fine but the taller one has more filter area.
14460
wix
Part Number: 51365
UPC Number: 765809513655
Principal Application: Ford (92-97), Honda (00-07), Infiniti/Nissan (95-09), Mazda (97-07), Mercury (91-96), Saab (05-06), Subaru (88-09), Cub Cadet, Yanmar, John Deere, Kawasaki, Kobelco, Outboard Marine Engines, Subaru 4EAT, R4AX-EL spin-on transmission filter
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 2.577
Outer Diameter Top: 2.685
Outer Diameter Bottom: Closed
Thread Size: 20X1.5 MM
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=15/22
Burst Pressure-PSI: 300
Max Flow Rate: 9-11 GPM
Nominal Micron Rating: 21
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.475 2.173 0.233
14610
wix
Part Number: 51356
UPC Number: 765809513563
Principal Application: Acura (02-09), Chrysler Imports (92-06), Ford Probe (93-97), Honda (01-09), Infiniti/Nissan (96-09), Mazda (71-00), Mercury Villager (99-00), Mitsubishi (90-09), Saturn (04-07), Outboard Marine Engines, Various HD Equip.
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.402
Beta Ratio: 2/20=6/19
Burst Pressure-PSI: 363
Gasket Diameters
other choices
SPECS
20 x 1.5mm threads
14 psi by-pass valve
anti-drain back valve
2.3" O.D. gasket
2.5" to 3.5" long
Filters - 3.5" BEST
Purolator Pure One PL14610
Mobil 1 M1-110
Bosch 3323
WalMart SuperTech ST7317 good quality and easy to find at Walmart
Filters - 2.5" BEST
Purolator Pure One PL14612
Mobil M1-108
Bosch 3300
Filters - 3.5" 2nd best - why use when you can get the best easily
AC Delco PF-2057
Auto Pro 2356
Autopride CF240AP
Baldwin B1402
Carquest 85356
Carquest Red B4620
Casite CF240
Castrol 7317
Champion Labs Ph2867
Defense Filters Dl7317
Deutsch D-370
Federated Filters LF240F
Fram Double Guard DG7317
Fram PH7317
Fram Tough Guard TG7317
Fram Xtra Guard XG7317
Group 7 V4610
Group 7 V4620
Hastings LF240
Mighty M4612
Motorcraft Long Life FL-821
Napa FIL1356
Napa Gold 1356
Parts Plus PH2867
Pennzoil PZ-109
Penske 7317
Powerflo SL14610
Powerflo SL14620
Pro Gauge PGO-4620
Pro Tec 164
Promotive PH4610
Pronto PO3593A
Purolator L14610
Service Champ OF-4622
Shell SH48
Shell SH529
Stp S-02867.
Valvoline VO50
Warner PH2867
Wix 51356
Filters - 2.5" 2nd best - why use when you can get the best easily
AC Delco PF1237
Baldwin B1400
Firestone TF2876
Hastings LF113
NAPA Gold 1365
Purolator L14612
STP S-02876
WalMart SuperTech ST6607
WIX 51365
WalMart SuperTech as a BEST filter.....
