It seems like most econo-car engines, even those in the B-segment (Yaris, Accent, Versa for instance) tend to be DOHC these days. When manufacturers like Honda and Mitsubishi can get by with SOHC designs with 4 valves per cylinder (and still make comparable or better power than the competition), why is this the case? Given SOHC heads are smaller, lighter and (I assume) cheaper, why go DOHC for smaller, relatively low power engines?
The only reason I can think of is ease of implementation for variable valve timing. Honda and Mitsubishi, of course, use VTEC and MIVEC to get variable valve timing by way of multiple cam profiles in a SOHC design (and other manufacturers have similar tech as well). But Ford's 3V 4.6 V8 in the Mustang GT shows that you can even use cam phasers in a SOHC design. Is the ability to continuously vary intake vs exhaust overlap important enough to drive the decision to DOHC? Are there other major factors at play?
