I have a '99 Sienna with 199,000 miles on it. Due to the reputation of this engine, I've been using synthetic oil since new (now GC 0W-30) and I also change out the PCV valve every other oil change - every 9000 to 10,000 miles. Well, the last two times now that valve has been clogged up solid. Gee, do I have to replace it every oil change now? What makes it clog up so fast?
I just replaced the valve cover gaskets and the inside looked great. No sludge and no varnish to speak of. So I'm pretty sure the engine is OK but that clogged PCV valve is new.
Edit: I should clarify "clogged up solid". What I mean is that the valve doesn't rattle, not that the hole in the bottom of the valve is clogged.
