These engines are having problems with the high pressure fuel pump cam follower wearing prematurely. The follower is similar to a lifter on a flat tappet cam engine. I believe that an oil with a higher zddp level may help. VW calls for VW 502.00 oil, but does anyone have any better ideas. Where can I go to find the zddp levels in different oils, I have looked at several manufacturers websites and have found nothing?
