I recently replaced the shocks on my Dakota. I have new tires and new outer tie rod ends too. The ride is still more bumpy and uneven than it used to be. This is my 2nd set of new shocks, I used Monroe Reflex. It's a 2WD truck and the coil springs are original. I have 99,100 miles on my truck.
Question is, how do you tell if the coil springs are bad and need replacement? Truck steers fine so I don't think it's ball joints and there is no noise or steering problems like it would have with a bad wheel bearing/hub assembly. All the suspension bushings look to be in good shape. I am trying to figure out if the springs are bad but don't know what to look for.
I appreciate any help you guys can offer.
