looks like CerMet just got US patent for the technology so there got to be more to it then just advertisement?
I would like to hear from Terry or Molacule on this topic...
Southfield Firm Gets Patent For Nanotech Ceramic Engine Conditioner
Southfield-baesd CerMet Lab Co. said this week it had received a United States patent for a nanoparticle ceramic conditioner product that restores metal and reduces friction in metal-to-metal environments.
The company says the process has proven to significantly improve fuel economy in both diesel and gas-powered engines, as well as provide energy savings in other mechanical devices. Performance and product life are also improved. This is the first product that allows inexpensive ceramic treatment of engines, without disassembly.
The benefits of ceramic parts and coatings, known for nearly 50 years, include increased part longevity, heat reduction, friction reduction, as well as anti-corrosion properties. The Department of Energy states that ceramics have been proven to dramatically improve performance, energy efficiency, power density, and in the case of diesel engines, lower exhaust emissions.
During treatment with CerMet -- an abbreviation of “ceramic-metal” -- engine oil is used to carry CerMet’s microscopic ceramic nano-particles to the friction zones, to bond to the metal surfaces without any disassembly or downtime. A physiochemical process transforms the metal’s surface into an integrated ceramic-metal structure that emulates the properties of pure ceramic and significantly reduces friction with a notable reduction in surface roughness.
The company said SAE J1321 Type II fuel consumption tests performed by independent testing companies worldwide, including Claude Travis & Associates, have verified that the CerMet treatment provides a measurable and repeatable improvement in fuel economy.
And, the company said, major carriers are documenting considerable increases in fuel economy and experiencing high return on investment. In addition to large and small fleet use, other applications with similar findings include engines and gearboxes that power trucks, buses and RVs, as well as marine and other applications. Recently, a city police department acknowledged fuel savings ranging from 10 to 15 percent after applying CerMet.
More at
http://www.cermetelab.com, or contact Richard Edwartoski at CerMet, (800) 372-7580, ext. 107.
