I have the known sludge prone engine from Toyota, the V-6 1MZ-FE from 1997 in an Avalon. I just replaced the PCV valve today, which was original (136,500 miles). The ball inside rattled a little bit, like it was slightly stuck, but not fully. When I took off the old PCV valve there was oil inside it and inside the hose leading from it. It was fresh oil from the engine, as it smelled from gasoline. I was wondering if it is normal to have some oil in the PCV system? I have had minor oil consumption issues (1 qt/2000 miles) recently and was wondering if this could also be from the worn out/gummed up PCV valve. BY the way, I used a new purolator PCV valve I assume this is good.
