Originally Posted By: The Critic
Motorcraft and Ford OE are not the same. AC Delco makes two lines of pads--one is OE, and one is the aftermarket DuraStop line.
What does AC Delco have to do with anything? I'll defer to your experience with AC Delco since I've ordered about one thing from them in the last 10 years, but I have ordered a lot of Ford parts and...
If you go into a Ford dealership and ask for pads for any Ford vehicle, they will come in a Motorcraft box, with a Motorcraft part number that you could use to order it from any Motorcraft retailer. They will also have a Ford OE part number on them, whether you get them from a dealership or a Motorcraft retailer.
If you decide to order the part by the OE Ford part number you'll STILL get it in a package that says Motorcraft on it and it will STILL be the same thing you could get from a Motorcraft retailer with the corresponding Motorcraft part number.
This is true for every single part for which Ford markets a replacement under the Motorcraft name.
All that being said, Motorcraft does have a "new" line of improved brake pads (the Superduty line) but this is not what was used in the test nor was it what came on the vehicle. I don't believe they were even available in 2003 when this test was done.
Prior to the Superduty line of pads, Motorcraft had only one line of brake pads, and this is still true for most Ford vehicles.
