Originally Posted By: Gokhan
Originally Posted By: kschachn
Really? I mean, who would have known, considering the manufacturer won't say and a VOA won't show it.
And even if it were - can you explain what difference that makes in terms of performance? Mobil's Visom is strikingly and significantly inferior to PAO? Because ExxonMobil says that it is not.
Of course, M1 EP is better than M1. M1 EP has a lot of Group IV PAO and Group V in it -- higher-quality base oil. M1 is mostly Group III.
M1 EP has certainly more Group IV and/or V in it than M1, as evidenced by
8.5% NOACK for M1 EP 5W-30 vs.
10.1% NOACK of M1 5W-30. However, it still has a lot of Group III -- only more Group IV/V than for M1 but still mostly Group III.
Don't confuse Group III or Group III+ with GTL. While Pennzoil's GTL comes very close to Group IV PAO in resistance to oxidation (while it still cannot match it), Group III or III+ still falls considerably short of Group IV PAO in resistance to oxidation.
Carefully and systematically done Amsoil tests also show that M1 EP did poorly in engine cleanness and wear protection in comparison to Pennzoil, Valvoline, etc. So, according to Amsoil tests, you will be far better off with Pennzoil or Valvoline (or Amsoil of course) than with M1 EP.
M1 EP is the worst in wear protection and second worst in engine cleanness among the ten oils studied.
Don't forget that all M1 oils also contain grp 5 as well. We need to give out accurate info on this. Here is a link from Mobil tech showing this.
http://www.mobiloil.com/USA-English/MotorOil/Car_Care/AskMobil/Does_Mobil_1_Contain_Ester_Oil.aspx
