Originally Posted By: ZeeOSix
The filter does essentially have a bypass valve when mounted to the engine. The PSID across the filter will still actuate the bypass valve if too high. Point was, the PL14006 would flow 12 GPM of hot oil with ~5 PSID, which is still below the 8~10 psi setting of the bypass valve built into to engine block on an LS series GM V8.
I got it, just being funny. However, with out knowing the output of the pump, it's a guess isn't it? I found a GM Tech Link today that said the LSA oil pump has a capacity of 33.8 gpm. I realize this isn't an average LS but how much lower would a "run of the mill" LS be?
Nope ... you would never know without testing both on the same flow bench under the same oil viscosity and flow conditions. The spec of "9-11 GPM max" doesn't say much unless it's assumed that is the flow rate of hot oil in a brand new filter at which the by-pass valve starts to open.
Ya the bench test would be awesome. I was thinking if we knew the pump output and could compare PSID but if we had a PSID graph for the Wix we'd have our answer, wouldn't we.
As far as the gpm max, I was assuming that it was the max that the element could flow.
Sorry, not trying at all to be difficult, just to understand and learn.
