Originally Posted By: river_rat
Originally Posted By: modularv8
I have noticed that some filter manufacturers give the MPFE at a certain micron rating (ie, 20 microns), then give the SPFE at 10 microns...
Here's one example where the efficiency is lower with muti-pass at 20 microns, than it is single pass at 15-20 microns.
Ecore multi and single pass %
I assume the continuous particle feed causes some to work through the media as it becomes loaded to the stopping point of the test, which is triggered by some maximum allowable pressure drop. This, of course, would lower the average and therefore the final percentage.
I agree that the thread-end bypass is better....all other things being equal. My filter sets thread end up, and I prefer thread end bypass in case there is debris collected in the bottom right near where the dome-end bypass would be opening.
In pressure tests with a stock size Wix filter, my filter goes into at least some bypass at warm-up even on warm days, and any time the engine gets much over 3000 RPM at full oil temperature.
The result for the Single Pass test (SAE HS-806) is for all particles captured in the range of 10 - 20 microns. The SAE J1858 Multipass (obsolete) test standard requires the use of medium test dust (5 - 80 microns). Of these particles in this range, 20 microns represents about 30% by volume of the test dust. Champion chose to only give the result of the 20 micron particles captured. The two tests are not equivalent nor are the results for the test particle size the same; therefore, different results with the Single Pass test showing a higher efficiency because mathematically it is calculating a greater particle range (ie, 10 - 20 microns; more particles to capture) upstream/downstream.
