Motorcraft SPFE = 92% @ 20 microns. SPFE isn't a real world filtering performance measure (marketing). MPFE represents a better approximation to real world peformance.
Got a link showing such specs? - I can never find anything much on Motorcraft filters.
Motorcraft's oil filter performance specs have always seemed to be lacking and confusing. At one time all they said was "80% @ 20 micorns", which seems way behind any other average oil filter these days.
No links, it is not a published spec. The SPFE quoted above is for the Motorcraft FL-820s and was given to me by Todd Vick, product engineering manager (OEM filter engineering) at Purolator. The media in the Motorcraft is not made by Purolator, so the 92% (test average) at 20 microns is from bench testing. The difference between 92% to 99% SPFE is insignificant compared to the filter's MPFE ...
Thanks for the info. So is the Motorcraft spec of "80% @ 20 microns" the multi-pass efficiency (MPFE)?
No. The "80% @ 20 microns" comes from a Motorcraft filter product information publication. The Motorcraft publication states that Ford doesn't specify what it is and Motorcraft appears to not know at least for the FL820s; however, Motorcraft does give specific values for other filters. However, the measured value for the multi-pass filter efficiency would be greater than the 92% SPFE. I have read alot of publications going back to the 1950's and it is evident that Ford has been very active in research and testing of many different types/designs of oil filters/media. Sometimes, Ford has gone against certain oil filter industry design trends. And it is interesting to read the old Motorcraft literature and automotive references from the 70's and 80's regarding Ford's filter media. I wish I had done some testing in those labs when I was at SWRI. In the end, unless you are just inquisitive, I wouldn't worry about it. If you own a Ford, running the Motorcraft filter is the best you can do for that engine.
