-60C??? You live in Antarctica?
You're saying that when mixed with water in the reservoir the one with slightly more alcohol selectively distilled out the alcohol?I used to mix in rubbing alcohol....70% worked great but the 90% evaporated, leaving me with a frozen reservoir again.
Yeah I agree, even though Karcher seems like a legitimate company, this product might only be useful for someone who experiences frequent thick frost, or doesn't have time to warm up their vehicle. Pretty interesting none the less. Paid promotions are very suspect, I've seen them on Lowes as well.??? Despite the fact that this product has nothing to do with unfreezing a windshield washer reservoir, I was intrigued. The fact that *every* user review on Home Depot's website for this product was "collected as part of a promotion" doesn't give me much faith in it. The amount of effort it would require to move a battery operated tool across a windshield would surpass that of an ordinary ice scraper and a bit of elbow grease, IMO.
I'm not sure any alcohol is the best thing for a paint finish, especially the higher concentrations. It's a solvent, and solvents are generally hard on paint-- some more aggressive ones are used to actually strip paint, so there's that.Yeah I agree, even though Karcher seems like a legitimate company, this product might only be useful for someone who experiences frequent thick frost, or doesn't have time to warm up their vehicle. Pretty interesting none the less. Paid promotions are very suspect, I've seen them on Lowes as well.
For those adding isopropyl alcohol to their washer reservoir, isn't it supposed to be bad for clear coats? Not sure if methanol is bad either but have been using it for years with no issues, just a faded plastic cowl after 16 years.
You're lucky to have that available, the lowest around here is -20F. You must be in a cold area if that's available.No, but it's more efficient to buy a gallon of that and add a gallon of water if needed.
At $12 a liter, regular windshield washer fluid is much cheaper. Plus it doesn't fix his problem, if the nozzles are frozen, they would have to unfreeze first and once they're unfrozen, you can just squirt out the old water and put in a regular windshield washer fluid.Doesn't contain ammonia or methanol so better for the paint maybe?
Edit: looks like its not for sale this season and has ethanol as it's main ingredient.
Um, ok. Say whatever you want as usual.You're saying that when mixed with water in the reservoir the one with slightly more alcohol selectively distilled out the alcohol?
No. Even if the vapor pressure was somewhat higher it will only fall to the level of the weaker mixture, not any worse.
Liking it doesn’t have anything to do with it.Um, ok. Say whatever you want as usual.
I can only report what I observed, which was:
90% mix refroze after a few days.
70% mix, same proportions, did not refreeze.
Same average temps, upper teens to mid 20s F.
Sorry you don't like it.
He's not lying. If the 90% mix froze whereas the 70% didn't, something else is at play here, not the alcohol concentration. Basic science.Um, ok. Say whatever you want as usual.
Yup. As I may have mentioned, it seems the 90% either did not mix or separated, and evaporated. This allowed the freeze point to climb enough for it to freeze.He's not lying. If the 90% mix froze whereas the 70% didn't, something else is at play here, not the alcohol concentration. Basic science.
But we can agree that it's not the 90% product that's at fault here, right? It's a proven fact (again, science), that 90% alcohol would be LESS likely to freeze than 70%, assuming the other constituent is water, all other variables being equal.Yup. As I may have mentioned, it seems the 90% did not mix or separated, and evaporated.
Actually, the gallons I bought are not a gel at all. Most hand sanitizers are sold as a gel, but a small amount (maybe 5%???) is sold as a spray. The sprays have the same consistency as drug store alcohol.It has to be in order to be made into hand sanitizer. Can't be sold without it. It's a gel though even at 80% so not sure how well it will do in the windshield washer tank. Methanol is really the best, but there's no way to buy it cheaper than windshield washer fluid. The -35 stuff is just a higher concentration so that's what you really need. I usually just dilute regular windshield washer fluid in the summer with water and then don't fill it up as it gets to fall and use it up and then just refill with pure -20 fluid. I also have a heated windshield washer reservoir, but I've never had mine freeze yet.
At the peak of early-mid 2020 COVID, we were getting all sorts of hand sanitizers available around here. Most were actually liquid (all stores were out of the usual gel stuff) because many came from local distilleries that didn't have the means/time/whatever to blend it into a gel. At work we even got some from our uniform company that came in a clear Lucas oil bottle, it was liquid also. Strange times, but I'd be willing to bet there's a lot of liquid sanitizer product out there.Actually, the gallons I bought are not a gel at all. Most hand sanitizers are sold as a gel, but a small amount (maybe 5%???) is sold as a spray. The sprays have the same consistency as drug store alcohol.
The Canadian solution would be to just run the winter -35C formulation year round, but that would be a little excessive in Kentucky. Like others have said just mix in some if the winter washer fluid or add some rubbing alcohol, methanol, etc can even use Vodka in a pinch. The washer reservoir is located in the engine bay in most cars so the heat from the engine will thaw it out as you drive.
