My understanding is that the fact that the engine is mounted in front of the axle is part of the problem with weight distribution (and therefore handling) in transverse engine FWD cars. If this is the case, why are there no "front-mid" engine transverse FWD vehicles? It seems like the engine could be flipped to be behind the axle with the drive shafts coming out toward the front of the car instead of toward the firewall.
Front overhangs could be shorter, although granted the hood might need to be a little longer overall. It doesn't seem like it'd be any worse than a FM RWD/longitudenal setup, though, and it'd have the efficiency and overall weight advantages of the transverse layout. Would there be some kind of problem with the arrangement, or would it just not make enough difference to be worth the packaging differences?
