Originally Posted By: geeman789
Originally Posted By: supton
Just ran out and checked. My 2004 VW Jetta Wagon, with 195/65 15's says 36 front / 45 rear. Max payload of 503kg or 1,109lb.
No small FWD car needs that kind of pressure in the rear tires... typical weight distribution with driver is up around 65% front / 35 rear...
Tires carrying hundreds of pounds LESS load don't need 45 psi , or 39 or whatever VW specs for US cars...
Euro specs are much much lower, and are the more typical 2 or 3 psi more in the fronts...
I think mine is about 60/40 distribution, and 3,000lb curb, with a GVWR of apparently 4,100---so I suspect my rear tires may see a heavier loading than Nick. With current regs only allowing posting of the pressure for max loading, that would explain my tires.
The car has been feeling weird ever since I put these tires on, with a low 32psi pressure. I just never thought about bumping them up.
