Originally Posted By: Clevy
Rpm measures Crank rotations per minute.
They are there just as another point of reference. The driver can see at what point to shift(manual)and whether there is any slip,which could indicate potential problems.
In the 70's and 80's they were in sportier type cars. Now they are there to make the driver think they are in a sporty type car.
Thanks for the info Clevy
So it measures the rotations/revolutions of the Crankshaft?
Personally, in automatics, I'd rather have other gauges that will give information I'm more interested in, such as outside temp, avg MPGs, more tripometers (use these to keep track of my fluid changes). I just don't see the need for a tachometer in automatics (then again, I'm not a mechanic. perhaps they are used to troubleshoot problems)?
Originally Posted By: mechjames
Revolutions per minute. Basically how many times your engine turns over per minute at whatever throttle you're at. It usually measures spark from the ignition coil(s) on a gas engine, and charging output from the alternator on older diesel engines. I'm not sure what they measure on the new ones, possibly using a crankshaft position sensor or the cam position sensor with multiplication.
What?
um, that really confused me too
I really don't understand "engine turning over." I'm quite sure it doesn't mean the engine is physically turning itself round and round under the hood. I'm not being a smartbutt here, I just really don't understand some of the jargon used in mechanic world. Thanks for the post, nonetheless, Mechjames
