truck,
What I was after was how does a person decide that their lube is doing the job well enough for them to tout the product? Statements like: "My lube seems to be doing a good job".
What are they basing this on?
I would like to comment on your post though...
When we monitor a chain, the only thing we can do, other than look at it to see if there are any physical signs of misalignment or other damage, is to measure it. We have to measure to know how much elongation from wear there is. Once a chain reaches between 2-3% of it's original pitch, it will start to deform the sprokcet teeth.
If we measure and know at what percent of growth our chain is, then we can remove it when it reaches ~1.5-2% and the sprockets will be fine to use with a new chain. Let it go past that, and you will be buying the whole set.
On kinking...
If you have a standard roller chain that is kinking, it has been greatly neglected. It takes a lot of oxidation and grunge to cause a standard chain to kink. If you follow a good maint. schedule, you should never see your standard chain kink.
Ring chains are a different matter. Once a ring has torn or been damaged in some way, it can allow water and contamination past the ring. This will cause the oxidation internally, even with a good cleaning and re-lube schedule.
Also...if you need to loosen your adjusters to have enough slack to check for a kinking chain, you are probably too tight to begin with.
One of the biggest problems I see folks having with chains is not adjusting them properly.
I have done an extensive write-up on proper maintenance of chains and sprockets here:
http://www.best-motorcycle-chain-lube.com/chain_maintenance.htm#chain-maintenance-top
On kinking...
