Originally Posted By: Uber_Archetype
Originally Posted By: MolaKule
Doesn't the water pump have a sealed bearing?
Lubricating the seal is the issue - not the bearing.
Originally Posted By: Shannow
They rub against each other, and are lubricated by a tiny film of water/coolant between the faces...that's all they need.
Therefore, it's logical to conclude that anything improving the lubricity of that "tiny film" will contribute to longer seal life.
You might as well spray WD40 on sealed hub hub bearing seals to give them a little extra lube.
