Originally Posted By: daman
This oil is on the thin side of a 30w, am i seeing that right?
Originally Posted By: Ben99GT
I don't think that viscosity is correct, I had a 6000 mile UOA of Ultra that showed a thicker viscosity than this VOA.
yea something don't seem right...
I'm not sure there's anything wrong here. While 9.7 is on the low end for virgin xW30 oil, its certainly within SAE spec range (9.3 - 12.5). It is a little lower than what's reported on the data sheet for PU 5W30 (
10.3), but probably within their product spec limits. Its definitely out of SAE spec for a xW20 oil (5.6-9.3), so I don't think its a mislabeled 20. I guess another possibility is that the Blackstone measurement was off (low), but still I don't think the 9.7 value is unreasonable for PU 5w30.
And I seem to recall reading that in contrast to conventional oils, the synthetics tend to
increase in viscosity with age - which would explain Ben99GT's observation of a higher viscosity than 9.7 for his UOA on this same oil. Well that, and normal variability in the virgin PU 5W30's viscosity from lot to lot.
Ah yes, found what I read -
look at the graph on page 8 of this article, it shows that conventional oils first thin with age, then thicken, while synthetics never thin - only thicken slowly.
