BTW, our Yellow Wasp Chain Saw oil contains seed oil derivatives.quote:
Some plant derived Bio-oils which may be used as lubricants are: {This list is NOT all inclusive since new bio-oils useful for lubrication are being discovered every day].
Peanut
Corn
Sesame
Soyabean -
Walnut
Macadamia
Grapeseed
Sunflower
Canola (rapeseed)
Castor
Jojoba
Palm
Crambe
Coconut
Safflower - a variation of sunflower, part of the sunflower family. Not used very much because of its naturally high levels of oxidants and short shelf life.
Meadowfoam - a very promising oil, similar to Jojoba in terms of high levels of natural anti-oxidants.
BTW, most of the oils from the major plant groups are genetically modified (with respect to natural plant species) to yield high oleic (high in 'unsaturated' fatty acid) contents.
In this new list, I have bolded those oils I believe to be the major contenders for formulation purposes in automotive applications.
You have mentioned this twice but with no supporting documentation.quote:
Vegetable oils are inherently unstable and will never ever, ever go in the crankcase of my car.
I respectfully recommend you do a search in the Patent Office, SAE, and TLT (STLE) on new Anti-Oxidant developments for bio-based lube oils.quote:
Sorry to say but High Oleic Safflower or Sunflower 85% Oleic, WILL even with a good 1-1.5% BHT AO form a "gooey castor oil type sludge".
Thanks, but all my work is in "wet" lubricating oils with performance and improvement additives.quote:
Do some research on drying oils.
SbDTC can be used as a secondary AO or in some cases, it can be used as a primary AO, depending on treatment levels.quote:
Van Lube 8610 Antimony never used but is not listed as a primary AO for seed oils.
