Because Maxlife is a low viscosity fluid. Most newer cars use a low viscoisty fluid. The low viscoisty fluids don't shear as much as the ATFs starting at a higher viscosity.Out of curiosity, why do you think valvoline’s only “universal” fluid is in their maxlife line? Doesn’t it seem like they could have a “universal” non maxlife version.
If that is the case, would it not be recommended for older cars? I don’t have a particular example but I believe it is says it is ok to use in some 90s transmissions, before lv fluid was mainstream or am I misinformed?Because Maxlife is a low viscosity fluid. Most newer cars use a low viscoisty fluid. The low viscoisty fluids don't shear as much as the ATFs starting at a higher viscosity.
In all reality, your transmission was designed for Matic J.Yes it meets matic j, it is a 5 speed.
I try and avoid discussing my "reasons" here as someone will too often spout their opinion on why it's wrong Castrol Import Multi-Vehicle meets Matic J (and many other specs) but does NOT meet Matic S. I don't need Matic S so I don't care. Your Frontier calls for Matic S or J or equivalent. Nissan (automatic) transmissions just don't care that much and they definitely don't need Nissan ATF contrary to what older manuals say or what some people say.l see from your prior posts you are a fan of castrol import. Why are you a fan of this fluid? Does it meet j & s?
To be clear they don't say it "meets the specs" of the Nissan fluid, as is the case with most suggested applications it is "suitable for use" or "recommended" for those applications requiring a certain specification or license.I try and avoid discussing my "reasons" here as someone will too often spout their opinion on why it's wrong Castrol Import Multi-Vehicle meets Matic J (and many other specs) but does NOT meet Matic S. I don't need Matic S so I don't care. Your Frontier calls for Matic S or J or equivalent. Nissan (automatic) transmissions just don't care that much and they definitely don't need Nissan ATF contrary to what older manuals say or what some people say.
Upon inspection, the valvoline import does not meet matic s.
any other options? Castrol or am I missing one of valvoline products? I thought I’ve read in the past one of the mercons is basically the same standard as a matic.
Yeah and I'm usually better about this distinction.... Oooops. What I meant to emphasize was that Castrol draws a line with "similar" applications that one product covers vs not covers. For example, IMV is good for Matic J but not Matic S (or later). Or I think they say it's okay for Honda Z-1 but not DW-1. For later ATF specs, they then recommend their "full synthetic" ATF (which are backwards-compatible with IMV coverage in most cases).To be clear they don't say it "meets the specs"
Don't use a LV fluid in older transmissions not made for it. I agree with the below answer:If that is the case, would it not be recommended for older cars?
To me, that's one of the best AT fluids out there, for non-LV transmissions.Castrol Import Multi-Vehicle meets Matic J (and many other specs)
It depends.... I believe Matic S is considered low viscosity and Nissan says it's completely okay for use in Matic J applications. Companies like Castrol, Valvoline, etc all say their LV ATFs are backwards-compatible in most cases too.Don't use a LV fluid in older transmissions not made for it.
I don't care one way or the other if the ATF is synthetic or not. It doesn't matter as long as it meets the tranny spec. I was just stating to the OP the fact that both Valvoline IMV & ML are a synthetic as compared to other brands of ATF who carry both a conventional & synthetic. This was just for the posters(Drewster01) information and it's their choice to make. It's called information & sharing.If it meets the manual, why does it matter if they are "synthetic"? Does the manual require that?
PS: This forum is full of fallacies like "Synthetic is better and needed". Including the mantra that "use LV instead of standard, in older cars, because muh... synthetic".
There isn't any proven benefit of using synthetic in a functional transmission versus normal fluid, as long as both meet the manufacturer specs.
Got it.Valvoline IMV & ML are a synthetic
Actually it’s exactly the same as all of the EU except Germany.Although, a side-note, the meaning of "synthetic base oils" is very stretched in US. Is not like in EU.
There is no tempting fate here at all. DEXRON-VI is the proper replacement for the no longer available DEXRON-III licensed fluid.I am currently running Valvoline Maxlife full synthetic in my 1998 Volvo S70 with the Aisin Warner AW50-42 transmission with no issues at all. The AW50-42 calls for a Dexron III spec fluid but I decided to tempt fate and run a Dexron VI, full synthetic formulation and MaxLife ATF works very well. I do a drain and refill every 15-20,000 miles. Transmission has 200K miles and shifts perfectly.
Per the PI sheet for the product, Maxlife ATF is "recommended for" those applications which require a DEXRON license. Nowhere does it say that it meets the requirements for that license nor is it a GM licensed fluid.I am using Valvoline MaxLife ATF which is full synthetic and meets Dex VI requirements as well as previous service requirements for a Dexron spec transmission
