UOA 2006 EVO IX, 3k miles, Rotella T6, E85 fuel
CA
First and probley only UOA I will do. I wanted to make sure the oil was holding up to the Ethanol as every time I change the oil it just reeks of E85. The car is raced frequently so Im suprized by the good wear numbers as I expected much worse. As for the sodium I have been a frequent Rotella or VR1 user so not sure if thats a additive in VR1 or not. The car has head studs but runs a decent amount of boost so would not be suprized if a little coolant found its way in the oil either, but I have not noticed any coolant being pushed into the overflow tank or coolant loss.
No problem. Also, it says 4B11, did you do an engine swap?
Regardless, wear numbers look really good even while under the influence of alcohol. Hehehe.
I noticed the downgraded engine listed but no still rocking the classic iorn block.
Lol. You're a 4G63 purist. Nothing wrong with that. You just made me laugh when you said downgraded engine. Awesome car!!
