So then which fluid is the best? dexron 6, redline or Amsoil?
You've asked this question a gizillion times.quote:
quote:
Info - Release of DEXRON VI Automatic Transmission Fluid (ATF) #04-07-30-037A - (Aug 19, 2005)
Release of DEXRON® VI Automatic Transmission Fluid (ATF)
2006 and Prior Cars and Light Duty Trucks
2003-2006 HUMMER H2
2006 HUMMER H3
2005 Saturn Relay
2005 and Prior Saturn L-Series
2005-2006 Saturn ION
2005-2006 Saturn VUE with 4T45-E
2005-2006 Saab 9-7X
Except 2006 and Prior Pontiac Vibe and Torrent
Except 2006 and Prior Chevrolet Aveo, Epica, Equinox, Optra
Except 2005-2006 Pontiac Wave
Except 2003-2005 Saturn ION with CVT or AF23 Only
Except 1991-2002 Saturn S-Series
Except 2006 and Prior Saturn VUE with CVT, AF33 or 5AT (MJ7/MJ8) Transmission Only
This bulletin is being revised to announce the use of DEXRON®-VI with the start of the 2006 model year production.
Please discard Corporate Bulletin Number 04-07-30-037 (Section 07 -- Transmission/Transaxle).
DEXRON®-VI ATF
General Motors Powertrain has recently upgraded to DEXRON®-VI ATF with the start of 2006 vehicle production.
Only 2005 and prior models that currently use DEXRON®-III may use DEXRON®-VI as a replacement.
All 2006 and future models that use DEXRON®-VI are to be serviced with DEXRON®-VI fluid only.
DEXRON®-VI is an improvement over DEXRON®-III in the following area:
DEXRON®-VI
Extended Factory Fill For Life 160,000 km (100,000 mi) For Cars and Light Duty Trucks*
80,000 km (50,000 mi) (Severe Use) For Cars and Light Duty Trucks*
Clutch Friction Stability Improved 100%
Clutch Durability Due To Fluid Improved 120%
Oil Film Thickness Increased 20%
Fluid Oxidation Improved 100%
Foam / Aeration Improved 150%
Shear Stability Improved 200%
* These ATF change intervals remain the same as DEXRON®-III for the time being.
2006 Transmission Fill and Cooler Flushing
Some new applications of the 6L80 six speed transmission will require the use of the J 45096 -- Flushing and Flow Tester to accomplish transmission fluid fill. It is highly recommended that the clean oil reservoir of the machine be purged of DEXRON®-III and filled with DEXRON®-VI.
Parts Information
Part Number Description
88861003 (US) DEXRON®-VI Auto Trans Fluid (1 Quart Bottle)
88861045 (US) DEXRON®-VI Auto Trans Fluid (1 Gallon Bottle)
88861046 (US) DEXRON®-VI Auto Trans Fluid (55 Gallon Drum)
88861004 (CA) DEXRON®-VI Auto Trans Fluid (1 Liter Bottle)
88861043 (CA) DEXRON®-VI Auto Trans Fluid (4 Liter Bottle)
88861044 (CA) DEXRON®-VI Auto Trans Fluid (205 Liter Drum)
quote:
Originally posted by The Critic:
Oh, and here's a little info for you on the improvements of Dexron-VI over Dexron-III(H):
2003-2006 HUMMER H2
2006 HUMMER H3
2005 Saturn Relay
2005-2006 Saab 9-7X
DEXRON®-VI ATF
DEXRON®-VI
Parts Information
quote:
Originally posted by unDummy:
Anyone have a non-GM product to try the Dexron VI in????
I already have a case of ATF+4 fluid for a Ford. Just waiting for the filter & cooler before doing the flush.
Bulwnkl, if you read the GM Dexron-6 info above, you'll see that a simple fluid SPEC can greatly improve the life of the transmission or at least the clutch wear by 120%.
Glad that I've been using Mobil1/Amsoil/Redline ATF's for 20 years. Can't wait until these boutique companies come out with group 4&5 light ATFs.
And concerning cold weather, the Amsoil, Mobil1, Redline..and some of the synth blends, even though they are thicker(7.2 vs 6.0) at 212F,they actually have better cP-40 numbers. To me, this means that Dexron-VI might not be all that they hype it up as. Sorry, but the cold specs are similar to MerconV. Nothing there to brag about. Seems that Dexron-VI, even though thin at 212F, thickens quicker as the temperature drops(maybe not as much group III as we hope).
If you really want improved MPG, then the ATF needs to be easiest flowing at all temps and not just 100c.
I believe that Molakule has said this before, but the main difference between Pennzoil Mineral and Mobil 1 synthetic automatic transmission fluid will be the basestock, and not the additive package. The two fluids will still use similar additive packages but the quality of the base oil will be much better with the M1 product, evidently. This is one reason why using a synthetic fluid does not automatically guarantee the ability to extend fluid changes beyond the recommended interval; the base oil may be able to handle it, but the additive package may not.quote:
http://theoildrop.server101.com/ubb/ultimatebb.php?ubb=get_topic;f=50;t=000049quote:
Originally posted by chesley randolph:
code:
voa 20,000 milie
iron 1 70
chromium 1 1
nickel 1 1
alum 1 25
lead 1 64
copper 1 99
tin 1 3
silver 1 1
titan 1 1
silcon 4 14
boron 118 44
sodium 6 2
pot 10 10
moly 5 5
phos 323 213
zinc 4 98
calcim 251 32
barium 10 10
mag 4 35
antimony 30 30
van 2 1
vis cs 40c 28.1 25
vis cs 100c 5.9 5.4
v.i. 164 157
tbn 2.75 3.15
Here's one for Mercon-SP, note the minimal viscosity change:
code:
voa 20,000 milie
iron 1 70
chromium 1 1
nickel 1 1
alum 1 25
lead 1 64
copper 1 99
tin 1 3
silver 1 1
titan 1 1
silcon 4 14
boron 118 44
sodium 6 2
pot 10 10
moly 5 5
phos 323 213
zinc 4 98
calcim 251 32
barium 10 10
mag 4 35
antimony 30 30
van 2 1
vis cs 40c 28.1 25
vis cs 100c 5.9 5.4
v.i. 164 157
tbn 2.75 3.15
http://theoildrop.server101.com/cgi/ultimatebb.cgi?ubb=get_topic;f=3;t=001053
Why not just get it powerflushed and remove all fluid at one time and put in new trans fluid, Amsoil or Dexron 6?quote:
unDummy,
Since when did fluids shear continuously without stopping ?? Fluids will shear THEN thicken up due to oxidation, so it won't shear non stop and lose 4.0cst by 100K.
There was a recent sample of Dexron-III (G or H revision) posted on a Jeep AW box. Fluid sheared more on a percentage basis compared to Mercon SP.
And if you had taken a sample of the Amsoil ATF on the Tundra at 20K, would it still be at 6.3+ cst??? Could it have been at 5.5 cst??? You can't answer that question.
As for Al's transmission, he had drained and refilled the unit five times with Mobil 1 ATF. Go back and reread the thread. If draining and refilling the unit five times with Mobil 1 ATF isn't equivalent to a full flush, I do not know what is.
