Originally Posted By: gpshumway
Originally Posted By: ZeeOSix
dino33 - the cars in your signature don't need a "high flow" oil filter. I doubt those engines put out more than 5~6 GPM at redline. Any known name brand oil filter will flow tons more than those engines can produce.
I wouldn't be so sure. Subaru 4 cyls are well known to produce over 12 GPM, the humble 1.8l "R18" in my Honda Civic puts out 13.8 GPM at redline according to the service manual. The K20 2.0l in the Civic Si puts out 14.3 GPM at 6,000 RPM and redlines at a screaming 8,000 RPM, which translates to ~19 GPM at redline. That's three engines from two Asian manufacturers. I wouldn't be surprised if Toyotas were of similar design.
I just said this in another thread, but it applies here too:
The unknown about these oil pump flow specs ... is that with no restriction of the engine on the pump's outlet, or is that the actual flow going through the engine's oiling system? If it's just the output of the oil pump without the restriction of the oiling system, then the actual flow through the engine could be less.
I highly doubt anyone has independently measured the flow rate, so the factory spec is open to interpretation IMO.
Quote:
There has been a long running internet myth that Purolators are "restrictive" ... I say not.
http://www.bobistheoilguy.com/forums/ubb...451#Post1619451
I agree that Purolators aren't any more restrictive than any other aftermarket filter, but
if the Amsoil chart of the Toyota and Honda filters is to be believed we have to believe one of two things; either they have really lousy media (doubtful) or they place a high priority on flow over efficiency.
They do have lousy, ineffective filtering media. The ISO test that was ran is THE test standard for efficiency. Amsoil is only reporting what the ISO test result was. If they fausly report the actual data, they open themselves up to lawsuit action from Honda and Toyota for making their products look inferior.
