I have a '94 Corsica with 156,000 miles. I've fixed lots of stuff on it over the years (including the intake gaskets)- most of it properly. The car runs good, everything works, gets good mileage, and is probably good for at least another 50k- possibly more.
I noticed a small antifreeze puddle near the passenger side wheel today. Looked around, cleaned things off real good, drove it, let it cool down, checking occasionally. I've finally determined that the coolant leak is coming from the timing cover gasket- it's a fairly slow leak, but enough to leave a 6" diameter wet spot on the concrete after sitting overnight.
There's very little room on the passenger side of this engine- is there enough room to remove this timing cover?
Looks to me like all the accessories have to be removed, then support the engine, remove motor mounts, tensioner, and vibration dampener, then the cover will come out. Have I left anything out?
If I choose to remove the cover, I'll go ahead and replace the timing chain. Any tricks to this?
What about the joint between the oil pan gasket and this timing cover? Should I just leave the original oil pan gasket in place, put some silicon on it, and put the thing back together? I'm assuming that one need not remove the oil pan to do this job... I sure don't want to.
I've also considered stopleak. I generally avoid the stuff, but I've SEEN the GM tablets work wonders. I'm seriously considering dumping in some of those GM tablets, tightening the front cover bolts, and crossing my fingers. This could defer this job indefinitely... or at least for a few years.
What do ya'll think?
