Synthetic 20W-50
SK, Canada
I recently purchased a Cub Cadet Z-Force SX Zero turn mower.
It has the Kawasaki FR730V Engine.
They are an air cooled engine, with a 2.2 liter oil capacity, & no oil cooler.
I think I am looking for an engine oil with a good HTHS quality.
Has anyone used the Valvoline SynPower Motor Oil 20W50 Full Synthetic motor oil? It has the API rating SP, which should exceed the SF-SL recommendations listed.
I don't see any oil analysis reports for this oil in its Virgin state.
Any other oil recommendations in a 20W-50 weight (or other) I should consider?
I would prefer to run a synthetic, but maybe just as well with a conventional oil being it wont be getting extreme engine hours in a typical year.
It is being stored indoors in a heated garage so a heavier weight oil isn't a big concern.
Just looking for others thoughts, have heard of complaints with these engine starting to burn oil if using a lighter weight oil.
Just use whatever thicker oil. i use st 15w-40 for the engine and st 20w-50 in the hydrostat. I can run it for 2 hours straight in the summer on my small farm but at home it would only run for like 30 mins so a thinner oil would be fine.
I have a 33 hp with about the same oil capacity and a 10w30 FS is okay but I use what I have..usually a FS or SS 10w40.. Works well.
I have tried 20w50 but I didn't like it and to avoid drama I'll leave it at that.
And I mow over 50 acres a week.. I run an old Fram Ultra for the filter
Mine (Kawasaki) doesn't consume any 10W-30. I really say you shouldn't even need a 10W-40.
Why not a 15W-50?
A 15W-50 would probably be as well as a 20W-50.
A 10W-40 would probably be fine too. Just thought the 50 would have a higher HTHS rating.
20W-50 gets me down to freezing temps. I will not have a need to start it at these temperatures, & if I do it will be in a heated structure.
Probably go with this one.
cant seem to find specs on the SynPower. Maybe the same stuff.
20w-50 gives me a wide range of temps, and should have lots high enough HTHS.
Might go back to the dealer and see what they have to offer.
I've used it in hydros, as well as Kawasaki and the Toro/Exmark Chonda V-Twins. Runs smooth and always looks good after draining it each season with no consumption. I have a neighbor and a friend with a tree farm who only use 20w50 in their machines.
Mobil 1 15W-50 is well known for protecting hard working air cooled engines perfectly. It's available for a reasonable price in 5 quart jugs at WalMart. Finding a synthetic 20W-50 for a similar price is not going to be easy.
The synthetic diesel oils are also very good choices. Rotella T6, 5W-40 is a robust oil, and Mobil 1, TDT, 5W-40 is even more so. Both will perform similarly in your engine, handle the heat and keep the internals spotless.
