Because the ST 7317 'in this thread' is consistent with the openings all open when viewed from the base end, I cannot make the leap here and say that this particular 7317 centertube is not as designed, ie., that both of the paired louvers should be open. Also, can't speak to what other have observed, but without dissection IMO, those observations are unreliable.
Now, if poster above did dissection/examination (not exterior observation) on the filters mentioned with reported results, then Champ could have an issue. It will be interesting to hear Champ's response
That said, looking directly at the dissected centertube now, it does 'seem' logical that both top and bottom double louvers/slits should be open. "If" this is case, Champ has a serious center tube stamping issue, and a recall would be in order. Just have to wait and see.
