Originally Posted By: dk1604
This should be easy enough to prove or disprove. Just do a complete flush with ATE Gold and then turkey baster the reservoir with ATE Blue. In a few months, before everything goes coffee coloured, check if any of the ATE Blue has made it down to the wheel cylinders. Any takers?
That's never before been done.
Actually, many people alternate between ATE yellow and blue fluids.
When I crack the bleeders on the calipers open, fluid with visible dark, cloudy streaks comes out for maybe a second. On occasion there are air a few tiny air bubbles. If the fluid were, as proposed by the professional mechanic, to reach indeed contamination equilibrium, that which I always observe should never occur. I therefore propose that basting the brake fluid (
) does not suffciently "refresh" the old fluid all the way down to the calipers. And it is right there inside the calipers where thermal stress and particles from wearing brake piston seals degrade and contaminate the fluid most. Basting the brake fluid reservoir will also not get rid of any trapped air in the system. Hence, even if performed by a master baster, the basting should be reserved for the Thanksgiving turkey, who's already dead and doesn't need any brake service.
