Semi-deep tends to be my first grab
Snap onThanks, which brand do you have?
It's only tangentially related, but do you have the sockets that go in a ratcheting (or fixed I suppose) wrench?1/4” drive 12mm
Quinn shallow/Snap On semi-deep/Tekton Deep
3/8” drive 12mm
Astro Nano/Gearwrench shallow/Snap On semi-deep/Gearwrench Deep
Thoughts:
Minimal difference between shallow and semi-deep in 1/4”. Probably not worth it.
In 3/8”, the Astro Nano sockets are almost the same depth as standard chrome sockets; may not need to own both. Dimensionally, semi-deep appears to fit nicely in-between shallow and deep.
Similar to the Astros but sort of reversed because the hex is smaller than the body of the socket, acting as a stop when dropped into a wrench
I have this set somewhere:It's only tangentially related, but do you have the sockets that go in a ratcheting (or fixed I suppose) wrench?
You explained it better than I could. Plus, some fasteners have an unusually short hex head - that only exacerbates the issue with long sockets.As to the topic at hand, overly long sockets apply shear forces you don't want, if you can't brace the head of the ratchet due to clearance or whatever. This can break fasteners that would otherwise have survived.
That's not exactly as useful, if for no other reason than you're locked into that weird exterior spline drive.I have this set somewhere:
8921 21 Piece 3/8" Drive Pass-Thru™ 6 Point SAE/Metric Tool Set - Gearwrench
Count on GEARWRENCH to get the job done. Get the 8921 21 Piece 3/8" Drive Pass-Thru™ 6 Point SAE/Metric Tool Set here.www.gearwrench.com
Socket length is totally an issue with the 4 and 6-tang locknut spanners for D44/D60/14b spindle nuts. If you try to torque them with a lever (vs a rotational tool like an impact), they just want to cock and lever out of the nut.Garage Journal has an inaccurate read on the thesis.
When you encounter a stupidly long fastener, it's not there for your benefit. It helps align something at assembly or is otherwise beneficial to the manufacturing process.
I got my long sockets when I had to do a Saturn top engine mount. If you look at the thing and the stupidly long studs you're likely to think you can do better. But those long studs are good for aligning the engine (possibly sitting on a jack being serviced) and "sucking it back up", LOL.
Ahh, I see what you mean.That's not exactly as useful, if for no other reason than you're locked into that weird exterior spline drive.
The ability to put a really short socket into any ratcheting wrench (reversible, flex head, extra long, stubby) can be priceless in certain situations.
It's one of those things you'll usually only need a couple times a year, but when it provides access that would otherwise be impossible, I promise you'll smile . The "pass thru" aspect is not really what I'm getting at (plus sometimes it's too small to be useful) but the short OAH is the key. View attachment 142331
I also have this tiny Power Torque set, runs 5-13mm and 13/64 - 1/2". These are kind of the "1/4 drive" equivalent of this style -- that's just my term as of course these are not square drive so actual drive size is not applicable. View attachment 142332
Craftsman used to offer these but long discontinued. Note here they weren't focusing on pass-thru at all -- just a shallow socket meant to fit in a wrench. They do have a ball detent which helps retain them and that's niceView attachment 142334
I’ve been using my Mountain ratcheting wrenches for those applications. The collar provides just enough clearance for those fasteners.Those pass-through socket wrenches, and normal gearwrenches, are godsends for rear struts on sedans where the nuts typically live in a cramped spot under the package shelf.
I was looking the other day... NAPA now thinks their Carlyle set (same thing) is worth something like $412!!!I’ve been using my Mountain ratcheting wrenches for those applications. The collar provides just enough clearance for those fasteners.
A 13 or 17mm would make more sense than 18mm. Especially for that price.I was looking the other day... NAPA now thinks their Carlyle set (same thing) is worth something like $412!!!
It's The Emporer's New Clothes approach: they're REALLY expensive so they must be REALLY good!
In typical NAPA we-don't-really-care-about-Carlyle fashion, the web listing is terribly inaccurate. There's 10 sizes in the set and IIRC it's 10-19mm with no skips.A 13 or 17mm would make more sense than 18mm. Especially for that price.
Yes, I see that now, 10 - 19mm. But, the price is now showing $449. I could swear it was $412 an hour ago.In typical NAPA we-don't-really-care-about-Carlyle fashion, the web listing is terribly inaccurate. There's 10 sizes in the set and IIRC it's 10-19mm with no skips.
They're "ok" but not $412 ok. Most of the different badges right now (Platinum, ATD, Mountain, Icon) are ~$200 -- which is still high IMO but not completely outrageous
