RP stayed distinctively purple in my low miles F150 for about 600 miles but that was the old formula. You'd think in a new engine, it would hold color longer but we don't know how much old oil stays in the engine.
The empty bottles is decent proof the job was done as you requested because the whole shop would have seen the tech decanting the bottles into another container. It would have to be a shop-wide "conspiracy" if it happened. Possible but how likely? Most shops would not tolerate such behavior from each other but some shops are bad all the ay through. Not many but some.
Ultimately, you could take a sample of the installed oil and compare that to a VOA of the RP oil. Yeah, that would cost you money but it would tell you whether you can trust the shop. No matter what, it's going to be uphill and a fair bit of effort for seven quarts of oil. Unless you do the oil analysis, you don't have much to go on. At this point, you just have to decide which hill you want to die on. Be nice to the svc manager, see what he has to say but turn your [censored] detector on full. If nothing else, stuff like this tells you whether you ever want to return.
