Originally Posted By: TrackerTracker
Originally Posted By: volk06
Its only harmful for cats if your car BURNS oil.
If not, you shouldn't have anything to worry about. Plus if you know how little those people on the tech line know, you wouldn't believe anything they say. Also, recommended does not mean you can't use it. Its SM rated, use it with confidence. SM is a gasoline engine specification and it meets those requirements so don't over think this issue.
SM reduced the P levels to 800 max. Most of those limits don't apply to 40w oils. That's why Defy 10w40 can be SN while all the other weights are SL.
I believe that it's the ILSAC requirements that require Phosphorous levels to be 800 ppm or lower (to extend cat life), not the SM requirements and Rotella does not meet the ILSEC requirement because their P levels are about 1100 ppm Phosphorous. I have all this in their email to me. So the quandary is this: what to do when the manufacturer themselves says NONE of their oils are recommended for use in gas engines with cat converters. NONE!
I do agree with you on the burning issue and I posted it myself about an hour ago: you might be safe if you don't burn oil because that's the main mechanism to get Phosphorous into the cat converter and if you do burn oil, even having a low P level oil (800 ppm) might not even save your cat converter due to oil contamination in general.
That said, I too have a dilemma: my BMW I bought used, came with (insert drum roll) Rotella T6 oil so I too have to decide what to do.......
Has it been in there long enough to have already killed the cat in which case I just continue using it or do I replace it with something better to preserve the cat? Before I can decide I would need to know what happens when a cat dies: does it plug up and need replacing at $1,000 a pop or does it just cease to produce clean air yet doesn't interfere with car operation? Any thoughts on this or the above post in general??
It applies to SM spec, not just ISLAC. Heres a good article that sums it up:
http://www.penriteoil.com.au/images/PENR0138_Penrite_Zinc Tech Bulletin.pdf
Did you see the part where 40w oil are not included in these requirements? So a 40w with higher levels of P and ZDDP can be SM/SN with higher levels than 20/30w oils. If an engine calls for a 40w oil and SM spec, there is not problem.
You're making a mountain out of an ant hill....
