Originally Posted By: DriveHard
I've replaced axles on both a VW and an Audi. Both times I started with the reman units. Both times, I got [censored] rebuilds and had to pull one or both of them and use the warrenty to try again. On my latest go-around I used Raxles, and got MUCH better units right from the start, that worked perfectly.
Its my suggestion to go right to raxles, and swap the entire axle. It will show up at your door. Pull the old, slide in teh new, send back the old in the packaging they supply...done.
VW/Audi axles appear to be higher quality than what you get when you get a rebuild. I will steer clear from rebuilds on CV axles from now on. OEM or raxles...
I like Raxles, too.
