Originally Posted By: Miller88
Originally Posted By: ccap41
Originally Posted By: clinebarger
Originally Posted By: CKN
I am not sure why everybody is recommending heavy truck tires. There are several "XL" rated tires that will suit your needs. Also, if you don't have any heavy loads the manufacturers equipped most half ton trucks OEM with any number of name brand "P" rated tires that would also be quiet and ride very smooth.
I was not quite sure from your post if your looking for a quiet tire or a truck tire.
If you have access to a "Big O" tire store or "NTB" tire store I would suggest the following-
http://www.nittocrosstek.com/tires.aspx?tt=3
I run these tires and they are ultra quiet on the highway.
Not all Michelin MS/2 tires are load range E, What's the big deal with running a LT tire on a Light Truck....They generally run a lot longer than a P-metric.
The old LTX A/S was even quieter than the M/S or M/S-2, But as they aged wet traction got really bad.
I would think an LT would only be less comfortable though. Heavier/stiffer I would think that would only give you a firmer ride.
The LT tire is what is going to be specified on a 1 ton van for a reason. It is designed to be used with the heavier loads.
I think you're mixing this thread with the other one about the GMC 3500 passenger van one. But you are correct.
As for this one(GM half ton) some do and some don't require a LT rated tire. but if there isn't going to be towing or serious loading and comfort is at the forefront I would think you'd want to stay away from an LT.
